Substituting resistors in Matchbox
Started by smashinator, August 26, 2004, 12:06:56 AM
smashinator
Can I substitute a 68 ohm resistor for the 62 ohm resistor on Q3 in the matchbox (from R.O.G.)?
What would happen if I used 4.7M resistors in place of the 5.1M resistors in the tone control?
I just want to use up the resistors I have, but I'll get the proper values if it will significantly affect the way the circuit performs.
People who say it cannot be done should not interrupt those who are doing it. - George Bernard Shaw
http://pizzacrusade.blogspot.com/
Lonestarjohnny
I don't think these value's will change the circuit that much, try it and see, and remember you can alway's tie 2 resistor's together to get said value.
Johnny
SIXTY TWO OHM TO SIXTY EIGHT OHM WILL VERY SLIGHT DIFFERENCE IN GAIN and tone
 the tc resistors< i'm not so good at calculating< you can also change frEq resPonse by cAp valUE.
 RC OR RESISTOR CAPACITOR NETWORkS SET ROLLOFF pOINTS.
 MY COMPUTER LIKES CAPITOLS MUCH TODAY...
B Tremblay
Quote from: smashinatorCan I substitute a 68 ohm resistor for the 62 ohm resistor on Q3 in the matchbox (from R.O.G.)?
The circuit will perform correctly with those substitutions.  I actually used 4M7 resistors during development and testing of the Matchbox.  I probably used a 68 ohm as well, since I don't remember ever having any 62 ohm on hand.
I should probably add a note about this to the article.
B Tremblay
runoffgroove.com
smashinator
