B+
Started by lightningfingers, September 12, 2004, 10:19:40 AM
lightningfingers
I'm building a real mctube II for a friend (as a gift, i'm not selling it), and i'm using different transformers for this one as the ones i used in my first one arent availible any more...i have a 12V 500mA one for the heaters, in parallel with an isolation transformer for B+, and I can't get the bloody thing below 210VDC. I have a 10K 2W resistor on the positive side (and one on the negative side for that matter) I have yet to put caps in there but I don't think they affect the Voltage (do they?). Any suggestions as to what I should do, I have 9 days to get it finished and I haven't even started the enclosure......
U N D E F I N E D
toneman
what's the question?
2 hi of voltage?
filament question?
Peter Snowberg
Do you have the whole circuit built and the tube installed? If you don't have a current flow, the resistors won't drop any voltage.
I really like higher voltages for tubes so I don't think I would worry about things. Can you point me to a schematic?
You could always add a zener diode to drop the voltage more. Just make sure you use one that can handle the current it will be seeing.
Eschew paradigm obfuscation
toneman
Regan
I wouldn't bother worrying about it unless your components aren't rated for that high a voltage. unless I'm mistaken, you would have over 300v  coming out of the isolation transformer(assuming you use 240v at the wall) thats a lot of voltage to drop.
Regan
Peter Snowberg
I don't like to make assumptions about what schematic was used.
As long as C1 and C2 can take the additional voltage, things look fine. :D Build away! 8)
lightningfingers
I think the components will handle the higher voltage, its the tube i'm worried about, I don't want to break it, it will be kind of hard to get another one.
How do I drop the voltage with a zener diode (where do I put it etc)?
U N D E F I N E D
Peter Snowberg
The (at least some) 12AX7 spec sheets say 300V max on the anode. That's not the B+ voltage, but the voltage on the anode. The B+ would be quite a bit higher.
I've used the "drifted" Fender values of 120K for the anode and 1.8K on the cathode with a B+ of 420V and had no problems. The tone was great too! :D
lightningfingers
Ohh right, they're ok with higher voltages :oops:
Thanks for the replies :mrgreen:
U N D E F I N E D
