A bit OT: effects loop hum
Started by jayp5150, September 27, 2004, 05:07:13 PM
jayp5150
I just noticed after replacing the 12VAC adaptor on my Digitech RP-series reverberator that I have a horrible hum if plugged through the effect loop of my 5150.  If I plug direct (up front) it does not do it as much, but the reverb sucks then.  I plugged a single cord from the in to the out of the loop, and no hum.
Could this be something in the power supply.  The only 12VAC 500ma I could find around here quickly was at Radio Shack.  It's a multi-selectable-voltage one for an answering machine.  The voltage and amperage matched, though.   Isn't that all that matters?
I did change the plug to the one from the original pwr supply, so it's not a bad connection.
Any clues where to go now?
Thanks ahead of time.
niftydog
if it is 12VAC output then the power supply isn't the problem.
I'm willing to bet it's a ground loop. Did it hum with the old supply?
QuoteIt's a multi-selectable-voltage one for an answering machine.
hang on... it's kinda unusual to have a multi-selectable output wall wart with an AC output... are you sure you haven't mixed up AC and DC wall warts?
niftydog
Shrimp down the pants!!!
jayp5150
I just double-checked, and it is AC.  It's 800ma, though, not 500 (the original was 500).  Shouldn't be a big deal, right?
It may have hummed a bit before, but not like this.  I'll try it in another room, or with a ground lift.  I didn't think of that before.
Thanks.
niftydog
cool. Just lift the ground on the lead from the effects loop to the digitech.
niftydog
