Wire Wrapped Resistor for LM3886 amp?
Started by smashinator, September 28, 2004, 03:26:53 PM
smashinator
I'm looking at the power amp project here: http://www.generalguitargadgets.com/pdf/ggg_lm3886_amp.pdf
What's this "10 ohm 2 watt resistor with 10-12 turns of #22 insulated wire"?
Is that something one can buy, or do I wrap a wire around the resistor and solder it at either end of the resistor?
How do I do that, and why is it there?
Has anyone built this?  Is it a good building block for a guitar amp?
People who say it cannot be done should not interrupt those who are doing it. - George Bernard Shaw
http://pizzacrusade.blogspot.com/
Peter Snowberg
That's a home-made inductor using a resistor as the coil form. :D
If you can find a 0.7uH 2amp inductor you could use that instead, but it will probably be easier to make your own.
My guess is that it was put there to reduce super high frequency transients, but that's just a guess.
Eschew paradigm obfuscation
smashinator
So would I ground the mesh at one end of the wire, and solder the wire to each end of the resistor?
***edit*** and thanks for the quick reply, by the way.
smashinator
Also, is an 18 volt Bipolar power supply something I can just buy?  I've searched here, and checked google, and haven't found the answer I'm looking for.   Maybe I'm searching for the wrong thing....
RDV
smashinator
I dunno...  :oops:   The project file says 18 dc volt bipolar power
Would this be what I want?
http://www.circuitspecialists.com/prod.itml/icOid/1703
Peter Snowberg
It wants a 36 volt power supply with a tap in the middle which is connected to ground. The normal way of saying that is that it wants a +/-18VDC supply, or a dual-polarity 18V supply.
Here's one example using fixed voltage regulators, but the current may not be high enough. You can always just leave out the regulators though. ;)
http://members.psyber.com/dibsed//CIRCATS/opamp-ps.pdf
Nasse
QuoteWhat's this "10 ohm 2 watt resistor with 10-12 turns of #22 insulated wire"?
I wound 0,7 mm copper wire about 15 times around a suitable sized pencil used as former maybe less than ten millimeters diameter so it fits loosely (not much touching) around the 10 ohm 2 watts resistor. And yes it is meant to be soldered at both ends of the resistor.
Quess 2x18 ... 2x24 volts 2,2 amperes transformer is good for 3886 amp. I used toroidal center tapped one
Aharon
You need a power supply something like this
http://sound.westhost.com/project04.htm
If you are making two boards for stereo or something,if you want it for just one board only half of that will do.
I would use transformers rated at least 2A.
Aharon
PS:I have the boards made already waiting to populate,I'm making two power supplies to feed the two boards independently,it's sort f a powered monitor for my little studio that I'm making.I'm really excited about this project and I'd like to thank JD and Dean for it,may seem easy but it's prone to oscillations if not done right.
Aharon
RDV
RDV
Michael Allen
I believe that after fullwave recification, the voltage from the transformer is multplied by 1.414. So to get 16v, you would need about an 11.3v or 12v transformer since that is easy to find. For a 35v supply you would use a 25v transformer as in the original project.
As Peter correctly notes, it is an inductor formed on the resistor.
It's there so that capacitive speaker loads and cables don't make the amp unstable and oscillate. The resistor damps the inductor's natural ringing frequency which could conceivably cause problems.
smashinator
Wow, where can I get a 36 volt, 2 amp transformer?  (well, one that will produce 2 amps at 18 volts...) A brief look through the hammonds on mouser's website didn't give me any joy.  Perhaps I'll have to actually go through the catalog when I've got a minute.
Do I actually need 2 amperes?  My plan is just to make a guitar amp, probably powering a 2x12 cab (this is VERY preliminary).
spongebob
Toroidal transformers are a good choice for such a project, I found one really cheap on ebay just recently. Try finding one with dual secondaries or a center-tapped secondary, and enough amperes!
A nice starting point for building chip amps is this page:
http://www.decdun.fsnet.co.uk/gaincloneindex.html
Here's a closeup of the TDA2050 amp I built a while ago, I soldered everything point-to-point, no PCB!
smashinator
spongebob - That site looks pretty cool.  Cool photo of your amp too!
Anyone else have any input on where to get one of these transformers?
Also, anybody have any thoughts on whether or not this poweramp would be a good building block for a guitar amp?
RDV
Quote from: smashinatorWow, where can I get a 36 volt, 2 amp transformer?  (well, one that will produce 2 amps at 18 volts...) A brief look through the hammonds on mouser's website didn't give me any joy.  Perhaps I'll have to actually go through the catalog when I've got a minute.
http://www.mouser.com/index.cfm?handler=displayproduct&lstdispproductid=416095&e_categoryid=24&e_pcodeid=54616
RDV
OK, here's the poop. For an amp with an LM3886, you want about 42Vct to 45Vct. I copped four 44vct toroids on ebay for $7 each a ways back for exactly this. This lets the 3886 put out about 45-50W on the +/-32Vdc you get from that.
If you go over +/-42Vdc on the 3886, it vanishes in a puff of (metaphorical) smoke and never does anything again. They're very sensitive to power supplies being too big.
smashinator
RDV - I guess I missed that one!   :wink:
R.G. - That looks like a significantly higher voltage than what's on the schematic.  Would I have to change anything on the schematic to use that voltage, or should I regulate it down to 18 volts?    I guess I need to do some reading about transformers....
