Minor ADA flanger question
Started by Thomas P., October 03, 2004, 11:15:33 AM
Thomas P.
Why does it run (does it?) two 512-stage sections in parallel?
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
...and then there was light
StephenGiles
I believe it's called Parallel Multiplex, and allows improved signal to noise ratio, but I'm sure Mike will be able to elaborate on that rather sparse offering!
Stephen
Vsat
Also effectively doubles the sample rate for a given clock speed - if you want to attain very short delays and are trying to nudge that clock past 1 or 2 MHz this method is very useful (BTW the clock is better than most and can be tweaked to go to 5 MHz).
Regards, Mike
Thomas P.
Why would it be usefull to have such a high clock frequency?
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
StephenGiles
All is explained here:
http://hammer.ampage.org/
go in about 3 pages and download the BBD info zip file - 5mb or so, and look at the SAD512/1024 pdf and there is a section giving you the info you want.
Stephen
Thomas P.
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
