Schematic Symbol Help
Started by Tony, October 03, 2004, 04:38:05 PM
Tony
Hi,
I found this simple schematic, but I am confused about the arrows that are coming off of the "100k trim pot" on pin#4 in the diagram. What are these arrows?
Located here:
http://machines.hyperreal.org/categories/do-it-yourself/schematics/AD633.ringmod.gif
Also, can anyone recommmend a good way to provide 15Volts DC?
Thanks,
Tony
puretube
those arrows point to the same points, as the arrows that are at the ps-pins (8 & 5):
the arrow up goes to +15V;
the arrow down goes to -15V;
Peter Snowberg
The arrows show connections to +15 for the one pointing up and -15V for the one pointing down.
That circuit runs from a bipolar supply which is more like two 15 volt supplies wired end to end with the ground connection going to the + side of the -15 volt supply and the - side of the +15 volt supply. The blue characters show the places where the circuit would connect.
-15V ----(- 15V +)---- Ground ----(- 15V +)---- +15V
Here's a very basic bipolar supply:
http://www.mitedu.freeserve.co.uk/Circuits/Power/dualreg.htm
And here's one with more filtering:
http://www.ozitronics.com/docs/k83.pdf
Eschew paradigm obfuscation
Tony
Hi,
Thanks for the help, I understand now. (Thanks for those bipolar referrences too.)
Tony
