switching between 2
Started by kristoipher612, October 08, 2004, 05:47:00 PM
kristoipher612
i was wondering if anyone has a schematic to switch between 2 or more pedals like the stuff on ROG.  i'd really like to be able to use them as a single 2 or 3 channel preamp without going through the trouble of building an effects selector, and an ABY box with the actual effects in between unless that's the easiest way to do it.  thanks a bunch
Kris
erio fraga
Well, I don’t know if this helps you, but I’ve just finished to put ROG’s 18th and Tweed  emulators in a same box and used 2 DPDT switchs as bellow:
        DPDT 1                                DPDT 2
          1    2                          1    2
          3    4            3    4
          5    6            5    6
       1 & 6 : “Out 1”                        1 & 6 : Out
             2 : In Effect 1                            2 : In Effect 2
             3 : Out Effec 1              3 : Out Effec 2
             4 : In                  4 : “Out 1”
             5 : Ground ( or millenium )      5 : Ground ( or millenium )
This is not na elegant or so chip mode, but works
Erio
