-15v / +15v from 30VDC Adapter '?
Started by petemoore, October 21, 2004, 10:24:16 AM
What would you suggest for obtaining a 15+ / 15-vdc supply from a 30VDC adapter [from an old printer]?
 It would be used to operate small signal amps like in my inductorless wah.
Paul Perry (Frostwave)
Not sure that the reply above was relevant, that is a DC supply.
I think an 'active splitter' circuit would be more like it.
Of course, it all depends what you want to drive with the supply.
WARNING: if it is an unregulated 30v DC, then be careful that whatever you make the active splitter from can handle any overvoltage (a lot of common op amps have max power supply ratings of +-15 or +-18, which gives no safety ratig at all).
I'm thinking of an active splitter made from an op amp with a power transistor pair added on the output (but in the loop) to give sufficient current.
It isn't really as easy at it looks.. but what is? :roll:
niftydog
perhaps a commercially available DC DC convertor module?
Switch mode supply?
I like Pauls idea, and there's probably something out there like it.
niftydog
Shrimp down the pants!!!
puretube
ooops, I missed the D in the 30V-adapter - sorry folks  :oops: shame
spongebob
Is it possible to open the psu adapter? If it's a simple linear PSU (not a switching one) - and the enclosure is big enough - then you could still do what puretube described, there *has* to be AC somewhere in there!  :lol:
