Talkin'bout caps... what do you use for output?
Started by bioroids, October 28, 2004, 09:38:26 AM
bioroids
That is, if you don't know what will follow the pedal, how big should the output cap be to let all the bass out.
I tend to use 1uf electros, this gives a cut off at 1hz aprox if the following pedal has a 100k input impedance
Luck
Miguel
Eramos tan pobres!
