rebote2 delay
Started by mathflan, November 08, 2004, 05:32:25 PM
mathflan
Hi!
I build the rebote 2 delay from tonepad.
But I  have some problems with the millenium bypass.
So which millenium ciruit work with rebote 2 delay??????????.
I have build the millenium 2 bypass but I have to let push the switch to activate the effect and the led.
http://sounddiy.free.fr
Hal
you need a DPDT, latching switch with this.  By "let push the switch" it sounds like you're using a momentary?
mathflan
Thanks for reply
I use a DPDT with 6 connexions.
In fact  I have to hold the switch to activate the effect and the effect stops when I release it.
Sorry for the english, I'm french
THanks
Marcos - Munky
You're using a momentary switch. You need to change it.
