Switching Again!
Started by Austin73, November 12, 2004, 03:58:45 AM
Austin73
I'm new to this site so please accept my apologies if this has been covered already. I'm in the middle of making a 4ms noise swash,, but actually fancy rackmounting it as I am running out of floor space. Was just wondering if there was any ideas on switching the unit on and off etc. I do have a behringer FCB 1010 footcontroller that has two relayed outputs for channel switching. Is there any way to implement this to bypass the pedal? Any help in the matter would be gratefully recieved as I don't want to have to make a footcontroller with a 30strand lead to it!
Cheers
Austin
Bazz Fuss, Red LLama, Harmonic Jerkulator, LoFo MoFo, NPN Boost, Bronx Cheer, AB Box, Dual Loop, Crash Sync
The Tone God
Long audio runs is a bad idea. You can build a remote footswitching system using something like relays or electronic switching. Check out Geofx, my site, and take a run at the forum search function on the topic. That should get you going.
Andrew
