therminish
Started by coreybox, November 19, 2004, 05:23:20 PM
bobbletrox
You know, speaking of proximity detectors, I think it'd be interesting to implement a piezoelectric-film pressure plate into an effect.  Instead of wagging your foot around in the air, you'd press your foot directly on the control surface.  A small circuit would allow the peizo film to drive the led in an optocoupler.
Here's some food for thought:
http://www.amp.com/products/technology/articles/interface.stm
zachary vex
Quote from: bobbletroxYou know, speaking of proximity detectors, I think it'd be interesting to implement a piezoelectric-film pressure plate into an effect.  Instead of wagging your foot around in the air, you'd press your foot directly on the control surface.  A small circuit would allow the peizo film to drive the led in an optocoupler.
piezo films don't produce a continuous output voltage.  the piezo effect is a dynamic one, hence electronic lighters that use a sort of spring-loaded hammer to bang on a piezo crystal to generate a spark.
in the past, a pedal called patch of shades used some kind of pressure-sensitive pad to control a filter, and it probably used a resistive foam (carbon empregnated) that changed values when smooshed.  you can experiement with this effect using black foam.
bobbletrox
Thanks Zachary, you've got a point there *doh*
Resistive foam you say? *ponders*
Paul Perry (Frostwave)
There's a photo here of a shoe with a pressure-sensitive resistor built into the heel, PLUS a skin resistance emeasurement device! Text calls the shoe "non-obtrusive"!!!!!!!!! not on stage, that is for sure.
http://vismod.media.mit.edu/tech-reports/TR-432/node5.html
Seriously, it is possible to bodge up a pressure sensitive resistor by sandwitching the conductive foam that chips are stored in between metal plates, put some return springs in or eventually it will be flattened.
bobbletrox
Ahh, the old sensor in the shoe trick.
troubledtom
Quote from: zachary vex
 hi Z,
    i 've talked to E.C. about marketing the device"patch of shades ". there are 2 versions. we'll see what happens.
      -tt
John Egerton
The qprox chip works...
I've tried it...
Idiot Wah mania!
Stay tuned.  :wink:
Save a cow... Eat a Vegetarian.........
