Kay Tremolo Depth mod?
Started by dirkfunk, November 19, 2004, 09:27:47 PM
dirkfunk
hey i was just wondering where you would add the depth pot on this layout?
and also what size pot would you use?
Dan N
The depth mod I've seen online uses a 100K pot. Lift the top of the 68K resistor out of it's hole. Attach the hanging end to lug 3 of the pot. Attach lug 2 into the hole you just took the resistor out of. Ground lug 1.
dirkfunk
Dan N
Oops! Sorry, the resistor goes to lug 2, and lug 3 goes back to the circuit! Good luck!
dirkfunk
also when i run my bass through this pedal i get really farty distortion? ia there anything i can do to make the signal cleaner? also when the effect is on but im not playing anything i can hear the tremolo is that right?
dirkfunk
also when changing the speed pot from a 1k to a 100k is there anything else you need to change as well, ie.resistor, caps?
