Oscilloscope software
Started by gtech, November 26, 2004, 01:40:29 AM
gtech
Ok, another one.  :)
This one looks good. I even tried it together with his wave generator and it worded.
I wanted a scope software for my laptop.
Here it is. Freeware of course.
http://www.digitalfilter.com/sftosc/sftosc.html
Here is the wave generator.
http://www.digitalfilter.com/wavgen1/wavgen1.html
Gilles
Sorry, I had to do it...
ragtime8922
I use my laptop for just about everything. How do you go about making the cable to use the software scopes on a laptop?
gtech
I bought a cable like this and changed the plug for a 1/8" mono plug for the mic input.
http://www.finitesite.com/gtechblues/My_images/TestLead.JPG
It was faster than building the whole thing.
I also adjust a small wave generator that I built to a standard level like 0.1V or 0.2V pep with a scope at work.
I can then use that level as a standard level that can be used to adjust the level displayed on the Laptop. From there, everything measure I take is correct.
That cable is to make measurements on a circuit. But I also have a 1/4" to 1/8" adapter cable that I use to go directly from the output of an effect to the input of the Laptop.
Btw, I also used for a long time, and still use Gtune.
http://www.jhc-software.com/gtune.htm
That's my reference when I tune a guitar with new strings or with a new set-up.
Gilles
ragtime8922
gtech, thanks. I downloaded the scope (yet another) and will make or buy and mod a cable. My main problem was that I wasn't sure if these could be used with laptops since they don't have cards with all types of connectors. Thanks again.
                                  -Chris
Fret Wire
Quote from: gtech
Gilles
I take it that the Wave Generator program isn't accurate, or needs to be calibrated?
Fret Wire
(Keyser Soze)
gtech
Well, I was talking about the hardware version of the Signal Generator I built that needs calibrating.
That's gives me the idea to check if I can use the software Wave Generator as a standard to adjust my hardware Signal generator.
Gilles c
Fret Wire
My mistake :oops:  I misread.
Fret Wire
(Keyser Soze)
gtech
