increasing output in the Sd-1
Started by abajakian, November 27, 2004, 04:19:56 PM
abajakian
Hey Everyone,
I recently finished the mods found on the Fuzz Central website to my Boss SD-1. The pedal now sounds wonderful, however, when I step on it, even though the output is at 10 it doesn't give me any volume boost. Sometimes I even lose some volume on it.
Are there any resistors I can change on it that will give me more of a boost? I'd like to have 0 dB be at around 5 or 6 and have a 25 dB increase in volume when it's cranked.
Aram
Fret Wire
You should have plenty of volume on that, stock or modified. Re-check your work, go over the trace side of the pcb with a magnifying glass to see if you have any solder trace bridging or broken traces. Check diode orientation also.
Fret Wire
(Keyser Soze)
jplaudio
try increasing R9 to 47k and/or  reducing R10 to 2k2 or 1k.
You should be getting a boost from the stock circuit, check your mods
