EH Tube box misc stuff
Started by aron, November 28, 2004, 02:44:03 AM
aron
Here's how I mounted my tubes. I used a piece of aluminum from one of my cheap boxes and cut out a rectangle AFTER drilling two tube holes in it that matched the tube holes from the EH enclosure.
Then I cut the rectangle using a tin snips/shears. It cut it so easily.
Then I drilled holes to match the tube socket mounting holes. Then drilled 4 holes in the corners of the rectangle to mount it with PCB mounts. I got some aluminum pcb mounts from Radio Shack that were the perfect size.
They only have 2 kinds - insulated and metal. The metal one is the perfect size. I mounted the sockets on the aluminum rectangle and then wired the sockets and then mounted the whole thing in the EH enclosure.
MartyMart
Thanks aron, good to know !
Marty.
