|AMPAGE| |GEOFEX| |AMZ|
May 22, 2013, 02:16:07 PM
891439 Posts in 97608 Topics by 28693 Members
Latest Member: Rawk100
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  SD-1 to OD-1??? 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] 2 3 Go Down Print
Author Topic: SD-1 to OD-1???  (Read 10649 times)
G Kresge
SD-1 to OD-1???
« on: November 29, 2004, 09:08:32 PM »
Based on the similarities in the SD-1 and OD-1 circuits, I'm wondering if anyone out there knows how to eliminate the "Tone" control in order to convert the SD-1 to OD-1 specs?
"Why!?" you ask?
 I love my OD-1 and don't want to take it out to gig with it and risk the inevitable "beer spilled in the stompbox" accident from the front row.
Thanks.
Logged
G Kresge
SD-1 to OD-1???
« Reply #1 on: November 30, 2004, 04:39:33 AM »
Anyone?
Logged
MartyMart
Martin L / Berlin for a while
WWW
SD-1 to OD-1???
« Reply #2 on: November 30, 2004, 04:58:28 AM »
Hmmm, I dont know how similar the circuits are ( would have to take a look inside) but I have both and I dont think they sound very "similar" at all ? My OD-1 is from 1979, so that could be a different parts layout !.
Two of my friends have had "vintage" pedals stolen from gigs, during a break or after sound check !!!!  NOT  cool.
There could be more to it than just removing the SD-1 tone control and to be honest, you are better off leaving it there to get the right sound with whatever guitar/amp your using at the time of your gig/session.
Perhaps just connect both and A/B until you like the matched sound, you could always carefully remove the tone pot and measure the value it's reading, then use a fixed resistor in its place ( there's a thread on this somewhere from yesterday?) or just "set" the tone knob with some hot glue, so you dont loose that "sound"  ??
Good luck anyway,
Regards,
Marty Cool
Logged
jplaudio
Guest
Re: SD-1 to OD-1???
« Reply #3 on: November 30, 2004, 11:22:14 AM »
Logged
cd
SD-1 to OD-1???
« Reply #4 on: November 30, 2004, 11:37:49 AM »
Don't bother removing the tone control.  Just change C2 to .0047u, and leave the tone control at 12 noon (no cut or boost).
Logged
G Kresge
SD-1 to OD-1???
« Reply #5 on: November 30, 2004, 04:19:43 PM »
Thanks very much guys. I appreciate the advice.
Logged
jplaudio
Guest
SD-1 to OD-1???
« Reply #6 on: November 30, 2004, 05:58:05 PM »
Logged
G Kresge
SD-1 to OD-1???
« Reply #7 on: December 01, 2004, 12:33:43 AM »
Quote from: jplaudio
1. Lift the end of R7 that connects to C4
2. Remove C4 and replace with a 10k
3. remove C6 and replace with C4
4. Disconnect the wires at pads 5, 11 and 8
5.  Connect the free end of R7 to pad 8 with a jumper wire
6.  replace C2 with a .0047 or you can use C6 (.01)
you now have an OD-1
use the left over pot for a warp control
THANK YOU!!!  Cheesy  Cheesy
Logged
G Kresge
SD-1 to OD-1???
« Reply #8 on: December 01, 2004, 04:56:37 AM »
Finished with the mod. Gonna A-B it with my OD-1 at rehearsal tomorrow.
Logged
jplaudio
Guest
SD-1 to OD-1???
« Reply #9 on: December 01, 2004, 08:54:25 AM »
let us know how it sounds Cool
Logged
G Kresge
SD-1 to OD-1???
« Reply #10 on: December 06, 2004, 03:59:38 AM »
Haven't gotten to A-B the two pedals yet. The adapter jack on my old OD-1 broke, so I need to swap it out before I test them back to back. Thanks again for the DIY tip! I'll let you know when I try it out.
Logged
G Kresge
SD-1 to OD-1???
« Reply #11 on: December 22, 2004, 11:13:35 AM »
I have finally had the opportunity to A-B the SD-1 Mod and an orig OD-1 (a later period model) and Although they were inceredibly similar, the SD-1 Mod was a bit brighter sounding with the controls set the same on both pedals.
How much of this could be due to what is done in step 6 below?
I opted to use the stock cap from C6.
G
Logged
Regan
SD-1 to OD-1???
« Reply #12 on: December 23, 2004, 02:10:01 AM »
I'm not sure how much different the early od-1 is from the later model, but they don't sound that much alike from what I recall.
Back in the mid eighties I had an early od-1(1979 I believe) and a friend bought a new one because he liked the sound of mine. AB'd them together and they were quite different, with the older being much nicer.
I know the older one used a different opamp, plus the switching was done different. Maybe that was the difference.
Regan
Logged
G Kresge
SD-1 to OD-1???
« Reply #13 on: December 23, 2004, 12:23:59 PM »
That's what I'm thinking too after thinking about it more... The OD1 that I really like is a 79 or 80 I think. The one I was A-B comparing with the SD1 mod is a later one. I'll check it out again, but I'm fairly sure that the op amps are the same in both of the OD1s that I'm working with. I'll have to do some more extensive shootouts after the holidays.
Thanks.
Logged
palthegiraffe
SD-1 to OD-1???
« Reply #14 on: January 04, 2005, 06:42:05 PM »
Could someone please clarify this instruction? Everything else makes sense to me.
Logged
jplaudio
Guest
SD-1 to OD-1???
« Reply #15 on: January 04, 2005, 07:26:01 PM »
Logged
jplaudio
Guest
SD-1 to OD-1???
« Reply #16 on: January 04, 2005, 07:33:31 PM »
Logged
palthegiraffe
SD-1 to OD-1???
« Reply #17 on: January 04, 2005, 07:57:57 PM »
Quote from: palthegiraffe
The OD-1 has a inverting gain stage using the second half of the OA . The 10k references the non-inverting input to the virtual ground. The output of the clipping stage connects to the inverting input through R7.
<palthegiraffe here admitting his ignorance>
I meant that I didn't know the specific part to put in place of C4. A 10K-resistor? A capacitor that's 10,000 nf?
I have severe limitations sometimes. That history degree does me no good when I'm modding pedals.  :roll:
Logged
G Kresge
SD-1 to OD-1???
« Reply #18 on: January 05, 2005, 03:16:51 AM »
[/quote]
The .01 should give a lower cutoff on the high pass (more bass) than the .0047.
There may be other variables including the opamp.[/quote]
Sorry, I'm unclear as to whether you're suggesting that I try using the .0047 to reduce the "brighter sound"? I'm not sure if I'm interpreting your post the right way.
Regarding the opamp(s):
The opamp in the OD1 (serial number 10200) which I really like the most of the OD1s I have is an NEC 4558C. I haven't gotten around to replacing the power adapter jack on this one for A-B purposes.
The opamp in the OD1 (serial number 0200) which I used for A-B purposes has a JRC4558D.
The opamp in the SD1 which I did the mod on is 4558DD. Is there *really* that much difference in the C, D, and DD suffixes? I guess that could be the case, since I don't know much about the subtleties of these things... Any suggestions or recommendations would be appreciated.[/b]
Logged
MartyMart
WWW
SD-1 to OD-1???
« Reply #19 on: January 05, 2005, 03:35:10 AM »
Quote from: G Kresge
The opamp in the SD1 which I did the mod on is 4558DD. Is there *really* that much difference in the C, D, and DD suffixes? I guess that could be the case, since I don't know much about the subtleties of these things... Any suggestions or recommendations would be appreciated.[/b][/quote]
The "DD" op-amps are apparently the later re-issue version and sound a bit "crap"
They were the ones in my Park G10r amp, which i replaced with Panansonic NE5532's - IMO that made a HUGE difference to the tone and drive of that little amp.
My OD-1 is from 1979 ( 6800 ) and has a 14 pin op-amp RC3403ADB
The board is thick cream coloured, almost looks like "perf" and the traces are all solid "solder" traces, like a vintage Phase 90 board !!
I would suggest the NE5532 or a Ti- RC4559p for a nice "quality" op-amp but for "original" tone maybe the JRC4558D  would be best ?
Marty.
Logged
Pages: [1] 2 3 Go Up Print
« previous next »
Jump to:
