Rebote2 Delay SOS!
Started by crawler486, December 01, 2004, 12:37:55 AM
crawler486
I've checked, rechecked, double checked every component, solder bridges and still I'm not getting any delay out of this project.
It only sounded like its bypassed. I made it using Tonepads layout.
Any suggestion where to check?
The PT2399 chip is not the problem cause I tried on a friends delay circuit.
I'm getting 4.8 volts on Pin 1 of the PT2399 chip.
Appreciate your inputs!! thanks
Boofhead
I think pins 2, 13, 14, 15, 16 should sit at about 2.5VDC.
If you are getting 0V on pin 2 you may have the electrolytic cap around the wrong way.  If you are getting 5V on pin 2 then you may have a short between pins 1 and 2.
crawler486
Thanks boofHead.
I have already checked the eletros orientation and they are all correct.
I'll measure pin voltages when I get home and will post it tomorrow.
