The circuit layout of the COT is more or less similar to that of the SHO (but w 2N1588 instead of the BS170 and other R-values).
IMHO soundwise the tube sound OD comes close to the COT50 due to the identical I/O-caps which filter the signal in a similar way.
BTW: the COT reacts very,very responsive to trannie hfe-tolerances. If you put 5 2N5088 into the COT you'll get 5 different sounds (more/less gain or distortion, harder/softer clean and crunch tone, more/less bass).
JHS
What is the point of bringing this up if..christian said that the '
Tube Sound Overdrive' i listenned to the clips and i got the SAME sounds with the one i builted.
So we are there aren't we?
