phase 90 noise problem
Started by John Egerton, December 04, 2004, 02:02:28 PM
John Egerton
hey guys...
I have a problem with a phase90 that i've built...
It swooshes and sounds excellent however when i'm not playing i can hear a very prominent swooshing oscillation sound thats quite annoying..
It follows the rate of the pahse obviously and is very continuous...
I was wondering if anyone else has had this problem?
John
Save a cow... Eat a Vegetarian.........
Mostly clicking or ticking...not too bad.
 Anything [noisey] getting into the front end of the phaser will cause the swoosh to sound. Try unplugging the input and see if it changes markedly.
 I used High Precision Low Noise opamps, not that the noise was a big issue with the 'test' TL082's I used even though I checked for wierd voltages on the pins before installing the OA's.
 The wiring of the Phaze 90 can cause noise. Are you useing a PCB? Offboard wires kept short?
