foxx tone machine problems 2n3565 or wiring
Started by jmasciswannabe, December 06, 2004, 10:36:56 AM
jmasciswannabe
It's either in the wiring ( I am using a 3pdt ) or I put the transistors in backwards. I used the 2n3565 transistors but they were round and i didn't know which way to put them in. I didn't use sockets either (lesson learned) so I dont want to change them around unless I can tell for sure they are backwards. The datasheet I found on the net doesn't show the round version of the fairchild 2n3565 one so that didn't help. Any advice on how to tell which is which? Also, I wired the switch as follows:
row 1 : lug 1 and 2 connected, lug 3 to row3 lug2
row 2 : lug 1 ground, 2 volume pot, 3 output
row 3 : lug 1 open, 2 input, 3 blue wire to board
any help would be greatly appreciated.....thanks!
http://www.generalguitargadgets.com/diagrams/ftmpl.gif
here is the build layout!
....the staircase had one too many steps
cd
Look at the bottom of the transistor (legs up), the orientation is like this:
http://geofex.com/FX_images/to1dwg.gif
jmasciswannabe
yup....that would be the problem all right....thanks a lot for the diagram, CD....it's greatly appreciated!!!!
