sound car compatible
Started by novice345, December 11, 2004, 03:30:07 PM
novice345
Hello
did somebody tel me how i can connect  my guitar or thr ouput of a pedal effect?
did the signal is the same?
di ineed to convert?
do you have a circuit ,shematic  for the convertion?
thank you
eric
p.s. sorry for my bad english (i live in québec,canada french spoking)
thank again, :oops:
Gilles C
Pourrais-tu donner un peu plus de details?
Tu veux connecter ta guitare ou une pedale d'effets ou?
Sorry, back in English: I asked for more details.
Gilles C
Sic
i think he's asking how to plug his guitar into his soundcard on his computer either from the guitar or from the output of a pedal.
bwanasonic
Wow, what an idiot I am! I thought the post was about how to jam out in your Citroen!
:oops:
Kerry M
Gilles C
Argg... Ok. I read SOUND CAR and didn't make the relation. My mind just imagined it was CAR related.  :oops:
The "minimum" would be: guitar - effect - mono to stereo cable - sound card line in
Better: use a stereo effect,
Even better: use a cabinet simulator, for example http://www.runoffgroove.com/condor.html
I use a Stereo Marshall Simulator I built. It works well. But Runoffgroove has better simulators now if you want to build one.
I also use a Korg multi-effect that has a stereo output, and enough signal to use the LINE IN of a computer.
You can use the mic input, but it is mono (no problem there) and the sound won't be as good I think.
You can use: guitar - sound-card, and it will work.
Gilles C
