two heads one cab
Started by raf, December 13, 2004, 07:30:12 AM
raf
Hi there,
I saw something advertised a while ago which allows you to use two heads into one cab, so you would be able to A/B between the two heads.
Is this something that can be made? The thing that was advertised costs about £250 (480$)  :shock: a bit pricey .
I heard once that you cannot connect two heads into a single cab by using a special jack (2jacks into one), as you would blow the heads. (I am not sure if this is true either.
Any help would be great.
Cheers
Raf
Alex C
These links might help you:
Link1
Link2
Alex
