DIY tuner out
Started by ejbasses, January 07, 2005, 09:53:11 PM
ejbasses
Hi guys
I wanna build a tuner out for my pedal board and i need some ideas. Where do i get the signal for the tuner? Plus where do i put the buffers? Can i build an FX loop too?
Four Strings To Rule Them All And In The Darkness Bind Them
Paul Marossy
On my pedalboard, the tuner is in series, first thing in the signal chain. If I were to add a tuner out jack, I would do it right at the guitar input. I wouldn't use a buffer, I would just wire it in parallel with the input to the pedalboard. I dunno, I guess a buffer before the tuner wouldn't hurt. And, sure, you could build an FX loop into it as well.
TheBigMan
I just use a small AB box.  I built it myself and it's only 3"x2"x1".
