vibrato---a junk box build
Started by lightningfingers, January 18, 2005, 01:54:42 PM
lightningfingers
Heres a strange little vibrato circuit, made from parts I had in my junk box. One transistor phase stage, and a phase shift oscillator. Both transistors I used were 2N3904's, I had lots of fun trying to get the oscillator to work with these low gain transistors. If a higher gain transistor is used, the 3k9 resistor can be changed to 2k2, probably to get a faster maximum speed. No depth control, subtle enough not to need one.
I really like the sound, lotts of hiss and hum, from the unshielded plastic box, sounds like a warped record.
Heres a pic from my no-res phone-camera
---Enjoy--- 8)
U N D E F I N E D
birt
hmm i might build that into the same box as my green ringer 8)
would you put it in front of the GR or after it?
http://www.last.fm/user/birt/
lightningfingers
Probably after the Green Ringer, a distortion before seems to bring out the pitch bend more. On the other hand with the amp cranked it kind of gets lost.
U N D E F I N E D
Paul Perry (Frostwave)
Good one, Lightningfingers! that circuit is much more 'interesting' than it first appears :wink:
I havn't built it, but it looks like there is not only tremolo, but some phase shift as well.
birt
why is the schematic in 2 parts and where should they be connected?
MartyB
I think the LDR is a light-dependent resistor that the LED shines on, i.e. a diy optocoupler.
MartyB
RDV
Quote from: birtwhy is the schematic in 2 parts and where should they be connected?
1. Because the LED and LDR are to be physically connected but their circuits are separate.
2. 9v+ & ground.
RDV
Paul Marossy
What did you use for your LDR?
Alpha579
you could use a jfet as a variable resistor as in Tims wobbletron if you didnt want to do the whole optocoupler thing,
nice work!
ALex
Alex Fiddes
lightningfingers
Quote from: Paul MarossyWhat did you use for your LDR?
Its a regular 5mm photocell, I measured 1M in total darkness, and about 100R with a laser pointer shining on the lens. :wink:
U N D E F I N E D
birt
Quote from: lightningfingers
you got a picture of such a photocell?
Ge_Whiz
Paul Marossy
Cool, thanks for the info. Looks interesting, I might have to breadboard it.  :wink:
RDV
If you put an electrolytic cap(say 22uF) between the LDR and Q1's emitter, wouldn't you have a tremolo then. Make it switchable and have either?
RDV
birt
Quote from: Ge_Whiz
Quote from: birt
http://www.rapidelectronics.co.uk/rkmain.asp?PAGEID=80010&CTL_CAT_CODE=&STK_PROD_CODE=M29399&XPAGENO=1
i think i've got one of those from a camera
lightningfingers
Quote from: RDVIf you put an electrolytic cap(say 22uF) between the LDR and Q1's emitter, wouldn't you have a tremolo then. Make it switchable and have either?
Cool Idea! I'll get another one on the breadboard and see. It also occurred to me that 4 stages with staggered cap values and an input buffer might make a decent low cost/low power univibe.
STAY TUNED 8)
U N D E F I N E D
