Adding an onboard circuit
Started by Mihkel, January 22, 2005, 10:26:16 AM
Mihkel
Hi
I'd like to add an onboard OD circuit ( Joe's Easy Drive) to my guitar, but i want to make sure i do it right. I drew up a diagram based on the original wiring and if somebody would check it and tell me if there's something wrong with it, i would grately appreciate it.
Original Wiring
Modified Wiring
toneman
Hmmm
not 2 sure why U picked off the pickup switching sw(?)
easier just 2 come off the wiper of the volume out.
Guess U want 2 go thru tone control 2(?)
(after the effect)
Gnds & pwr look OK.
Seems like it would B easier 2 put circuit in a stompbox(?)
If the pickups are *powered*, then U already have batt in guitar.
U R adding DPDT sw 2 sw OD in/out.
U will have full output of pickups into effect.
No provision for reducing volume into effect.
Looks feasable......
afn
tone
TONE to the BONE says:  If youTHINK you got a GOOD deal:  you DID!
Mihkel
You're saying that it won't go through the pickup selector anymore?  I wanted it to go before the volume control so i wouldnt need to add another pot for the circuit.
Mihkel
So, to sum it up, would it work?
Joe Davisson
It looks alright to me, might need a 1M pulldown resistor before the input cap (& after output cap) on the Easy Drive circuit to prevent popping. It should even run on a 3v disc battery, but I haven't tried it. Would need a lower collector resistor: 22k instead of 68k.
Where are you putting the DPDT switch?
Mihkel
Quote from: R.G.Where are you putting the DPDT switch?
What do you mean exactly? I have the DPDT switch shown on the diagram.
samzeppelin
were on the guitar? of course  :D
page rules
Samuel
maybe he means physically? where in the guitar are putting a dpdt?
Mihkel
Ooh..right...
See this picture of the guitar: http://www.ibanez.co.jp/world/products/eg/pict_big/GAX30JB-2B-01.jpg
(Yeah I know it's not an excellent guitar, but its good for the price)
The switch goes either on the right of the pickup swith or between the pots.
al3151
Go to StewMac and get a DPDT push-pull pot.
http://www.stewmac.com/shop/Electronics,_pickups/Components:_Control_pots_and_knobs/Control_Pots.html
Those concentric pots are cool too but require those special metal knobs.You could use one half of the pot to control tone and the other half to control boost volume.
