Psuedo random LFO schematic?
Started by nirvanas silence, January 26, 2005, 02:52:03 PM
nirvanas silence
I found alot of great info on a page from Geofex but there were no reccomended starting values or formulas for finding the right value so I'm curious if anyone has experience with this.  Thanks for any tips.
The Tone God
Are you talking about a smooth LFO like for a phaser or a random digital LFO for sequencers ?
Andrew
nirvanas silence
Not a smooth LFO.  Here is the link I was referring to.  I just basically want to know how to figure out what values to use for the parts.
http://www.geofex.com/Article_Folders/LFOs/psuedorandom.htm
The Tone God
There are probably no values for the same reason I don't include values on some of my schematics. The values depend on what you are looking for. What are you trying to drive with this LFO ? What range are you looking for ? Since the oscilator circuit R.G.s is using if pretty common and is in the datasheet there is usually simple formulas for calculating the speed.
Andrew
Paul Perry (Frostwave)
Try 200K and 1 uF, multiply or divide the cap by 10 or so until you get what you wnat.
nirvanas silence
Ok great, thanks to both of you guys, I appreciate it.
http://www.cgs.synth.net/modules/cgs21_super_psycho.html
Ken Stone's Psycho LFO here will give some starting points as well.
Also, he sells boards!!!
amz-fx
Here is the noise circuit from the Roland TR606 drum machine.  You can filter this noise source to get a low frequency signal:
C92 is the output and I would make it 1uF if you're going to low pass filter it.
If you gate this noise source you'll get a noise splash like a cymbal, or you can sum it with a drum sound for a snare sim.
regards, Jack
Like I said, the more non-correlated oscillators you add, the better the noise.
