Carbon Film vs. Metal Resistors
Started by Hailstorm350, January 28, 2005, 12:17:10 AM
Hailstorm350
I have read up on the differences between Carbon Film and Metal film type resistors, but how do they REALLY affect sound?  as I understand, Metal film caps are more precision compared to carbon films.  In, say for an example, the BSIABII, where would Metal Film resistors sound best, and where would Carbons sound best?  I'm pretty sure that there's a reason for using them in different spots because in professionally made pedals like DynaComp they use different types all over the place.  Not just all Metal Film or Carbon Film.
I am just wondering because I am learning about the way components affect sound differently.
Thanks,
ken
Now, don't you start that again!
Alpha579
theres not alot of difference in sound (tone snobs will tell me otherwise :wink: ) , but 1% metal films will be slightly quieter than 5%carbon comps...
Alex Fiddes
MartyMart
Hmmm, are we talking about "Carbon film"  or "Carbon comp"  here ?
There is a HUGE difference, carbon film are just regular resistors, not particularly bad/good, but "carbon comp" are those "brown" vintage jobs from Fuzz Faces  etc... very different "tone" but can be noisey as hell !!
I use a mixture of "Metal film" and normal "Carbon film" all the time with no noticable difference.
Marty. 8)
Peter Snowberg
Carbon comps are great to bias Zener noise sources. ;)
Metal film is necessary if you're wanting to get rid of any possible noise source you can, but for stompboxes carbon film works just fine.
Eschew paradigm obfuscation
bioroids
Hi!
For my line of pedals I'm starting to use (just ordered) metal film resistors for the high values (greater than 470k).
As you know the higher the resistance the higher the noise, so the difference (if any) would be greater in these values than in, say, 1k resistors. Besides they tend to apear at the opamp's inputs, or biasing the base of a BJT, critical places I think.
Maybe is just a waste of money, but is not that much money anyway :)
Wich other places could be critical regarding noise? Everything on the signal path I assume, but perhaps other places?
Luck!
Miguel
Eramos tan pobres!
Paul Marossy
I think that I remember reading in RG's write up on carbon comp resistors that they just added more hiss in 9V stombox circuits...
mojotron
The power rating has a lot to do with the noise level you get out of carbon comp resisters - the noise is really noticable on 1/8W carbon comp parts. I just use metal film for everything in the signal path, and carbon film once in a while for biasing - the pots already add enough noise to the circuit. Normally I reduce noise everywhere I can, but I actually like the sound of 1/4W carbon comp parts in a Ge fuzz face.
NaBo
i use metal film if the store has the value in stock... if they're out or don't have it, i go to the 1/4 watt carbon films before i resort to the 1/2 watt metal films (which i only had to do once).  and i don't give it another thought.  everything i've built has been totally silent, even without an enclosure...  and practically no rf interference cuz i ground to my metal desk... i find an alligator clip fits quite nicely into the keyhole...  im getting off-topic.
anyways, in most cases you probably wont hear or notice the difference
Alpha579
Quote from: MartyMartHmmm, are we talking about "Carbon film"  or "Carbon comp"  here ?
Marty. 8)
have you actually heard the difference in tone between metal film and carbon comp? Im sure there will be more of a difference in high voltage tube amps, but at 9v the difference in tone will probably be value drift due to bad tolerance...
Alex Fiddes
RedHouse
Easy;
Carbon Composition = HISSSSSS
Carbon Film = HISSSSSS
Metal Film = HISSSSSS
Look elsewhere for Mojo.
Hailstorm350
jimbob
For the 9v circuits we mess with around here, I bet youll never hear any difference. I say go with either= .02 cent price difference at mouser so u cant lose. I use both.
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
Peter Snowberg
Quote from: RedHouseEasy;
Beautifully stated!!! 8) 8) 8)
Paul Marossy
QuoteBeautifully stated!!!
Agreed.  8)
bigjonny
I have no strong opinions, but for what its worth: I built the BSIAB II with all metal film resistors.  Quiet as mouse.
I guess my perspective is: when you're talking a couple bucks price difference for bulk purchase, why not go with the best?  Plus, ¼W metal film resistors are physically much smaller, and thus easier to fit into perfboard/stripboard designs.
That said, i still use carbon film when its more convenient for me.
NaBo
they're also a pretty blue colour!  :D  ...  :oops:
vdm
ive always used a mixture of carbon film and metal film, and i was wondering what the difference between the watts rating is. is higher wattage more or less noisy? my local shop only sells 1/2W metal films, but they're the same size as 1/4W carbon films.
im getting having carbon comp resistors put in my vibrochamp 'kit' from ceriatone... it's a pretty clean amp, so hopefully the hiss wont be too much of a worry, and the tone will be great :wink:
then again isnt that what we all wish for ....
trent
