Tube preamp tone stack needed
Started by electrictabs, February 01, 2005, 06:55:41 AM
electrictabs
Now let’s say that we have designed an all tube preamp that with a set of switches,relays etc. can emulate some of the most desirable amp sounds like Fender,Marshall,Boogie,Soldano,etc.
What kind of tone stack (treble,mid,bass) should we put after the last triode(it’s a cathode follower).
We want a tone stack that would be useful in a Fender emulation but also in a Marshall or Modern one. Right? Would  the passive marshall or fender tone stack be appropriate for this…
Is there any other tone stack(passive or active) that could do the job?
Mike Burgundy
If you look at a Fender tone stack and a Marshall one, new or old, you'll notice it's the same circuit.
The Marshall has different values an a little less range.
google is your friend...
electrictabs
sorry for that
When i say fender i mean the blackface tone stack
when i say marshall i mean bassman or plexi tone stack
they are a bit different...
Mike Burgundy
Theyre both 3-band standard Baxandall stacks, with different values. As far as I know., anyway (blackface twin: Baxandall blackface super reverb: Baxandall 100WPlexi: Baxandall JTM45/fender bassman: Baxandall... Am I missing something here?)
Experiment, I'd say
electrictabs
Yes I know they are similar circuits
my only quest is to find a circuit that would do the job for each setting(Fender clean,Marshall Crunch,etc) thus being between the most known tonestacks in sound alteration.So as you said i guess experimentation is the only way...
QuoteSo as you said i guess experimentation is the only way...
There are some things that circuit simulators are really, really good at.
This is one of them.
electrictabs
Yes...
I checked Duncan TSC
and I found out that the Marshall circuit can somehow do what the Fender does sonically so I guess that's my thing...
puretube
ragtime8922
Check out the "tone stack" section of the "Adams Amps" site. He has a Dumble tone stack that, if I remember correctly, was a Fender/Marshall with a bunch of switches that adds a ton of versatility to the tone. Also, again by memory, it was the only tone stack on that page that was "incomplete" but it was only a matter of a couple of values.
http://amps.zugster.net/main.html
