active booster...help needed
Started by mattdowney, February 01, 2005, 07:36:18 PM
mattdowney
i just wired a active booster from guitarfetish.com into my guitar. i did all the wiring correctly and have went over al lthe conections with a multimeter for continuity. it still isnt working. the booster has 5 positions, bypass, full bottomed boost, upper mid boost, mid/trebal boost and big overdrive/mid boost. when i am in the first position it is fine, my normal guitars sound. when i switch it up to the second position there is the tinyest bit more bass, but almost no difference, you really have to listen for it. the 3rd and 4th positions are no different from the second and the 5th position has a tiny tiny boost in volume, but you cant notice it unless you listen for it. i am sure i did everything correctly. does anyone have any ideas of whats wrong? it has to have more boost then that. has anyone used one of these before? did it work well?
thanks, matt
can you provide Pin voltages and probe info? Schematic ?
