Wiring a Switch (on-on) to Select Between LED and Diode
Started by charles, February 06, 2005, 06:24:20 AM
charles
Hi guys,
I am trying to do DS-1 mod in Fuzzcentral.
How shall I wire a selector switch to switch between a LED and a diode?
Instead of completely replacing one of the clipping diodes to LED, I wanna get both sounds by adding a switch.
RickL
Wire it so that the LED is always in the circuit. Wire the diode in parallel with the LED through a spst switch. When the switch is open only the LED is active. When the switch is closed the lower voltage drop of the diode will kick in before the LED, as if only the diode was in the circuit.
charles
Thanks Rick.
How would it be different with dpdt switch?  I got on on lying around...
(obviously...I am a beginner here... :-) )
RickL
Although it's a bit of a waste you can wire the dpdt exactly the same way. Use one of the middle lugs and one of the outside lugs, it will operate as a spst switch.
123
456
dpdt switch lugs viewed from the back.
Use 1/2 or 2/3 or 4/5 or 5/6.
Note, if you have a spdt or dpdt switch that is centre off (the toggle has 3 positions instead of 2) you can choose between 3 sets of diodes. Just connect the third set of diodes (or third diode if you're only switching one diode at a time) to the open lug on the switch. The other end of the diode(s) goes to the same place on the board as the free end of the first switched diode(s). This would let you choose between, for instance, LED, silicon and germanium diodes.
In the above diagram silicon would go to 1, wire to the circuit (one end of LED) to 2 and germanium to 3. Free ends of both silicon and germanium would go to the other end of the LED in the circuit. Just make sure you keep the polarities of the diodes the same if you're only switching one diode at a time.
modmod
sorry i dont quite understand how to do that with on-off-on spdt toggle , say if i wanna switch between led,1n4001,1n4148. how should i wire them all into 1 spdt ? could anyone kindly draw a simple diagram of that ? thx
modmod
Quote from: RickLWire it so that the LED is always in the circuit. Wire the diode in parallel with the LED through a spst switch. When the switch is open only the LED is active. When the switch is closed the lower voltage drop of the diode will kick in before the LED, as if only the diode was in the circuit.
am i correct ?
Khas Evets
You can do it that way to control one side, or wire back to back diode pairs using the same switch.
modmod
so led and 2 other diodes will only active ONE at a time with just a single spdt ?
RickL
Short answer, yes. In the middle (off) position only the LED is active. In each of the other two positions the other diode will conduct before the LED, so the circuit acts as if the LED isn't there.
Sebacore
How would that diagram be different is it was a spdt on on?  If someone could just do a diagram of that like the one above that be great.  Thanks
edit:  Nevermind i just looked at it a little harder and figured it out
Christopher N Anderson
