Submini Tube Power Supply
Started by ragtime8922, February 07, 2005, 09:08:07 AM
ragtime8922
I am ready to make a power supply to power up my submini tubes for a project/testing. I just ordered a toriodal tranny (the EH type from digi-key 12v wallwart in, 160VDC out). All the examples of apps for these trannys do not show how to get the 6.3 filament voltage. Does anybody have an idea or a rough schematic?
puretube
http://diystompboxes.com/sboxforum/viewtopic.php?p=200736#200736
http://diystompboxes.com/sboxforum/viewtopic.php?p=200758#200758
click ON...
if I`d wanted to power up 6V tubes, I`d use a 6...9V AC wallwart...
(maybe a lowdrop reg...),
or would think about wether I was going to use 2 identical tubes...
ragtime8922
Quote from: puretubehttp://diystompboxes.com/sboxforum/viewtopic.php?p=200736#200736
click ON...
If I change the value of the wall wart the output, which is based on the tranny ratio, will give me a much lower B+. I need at least 160VDC. I was thinking that I'd use a voltage divider but not sure how the whole power supply's schematic should look.
Thank you for the links.
puretube
i think it`s all in there - somewhere (link ON...)
