simple diode question
Started by barret77, February 08, 2005, 05:15:38 PM
barret77
Hi
just looking to know something:
If I change a diode rectfier in a circuit with another one, with  superior performance, and higher Voltage/Amperage capabilities, do I need to tweak this circuit somehow or can I replace the part and be happy? Is there a rule for this?
This regards switching a 1N4007 for a  DSEI 12-12A  (a FRED)
thanks!
jmusser
Somebody else can chime in if I'm wrong, but I believe that if the circuit calls for something like a 1N4001, and you have a 1N4004, that it will be a suitable substitute for our applications. It has the same characteristics, but can be used in a higher voltage application without smoking, such as power supplies. I'm sure I have done just that from where I've stripped them out of a TV chassis or something. It's on the order of using a 2 watt resistor instead of a 1/4 watt. If it's the same value, it doesn't matter, it'll just take up more room (and on diodes, the package size doesn't change much if any in most cases). I have no idea what the DSEI 12-12A diode is, but I believe that's how it works with like diodes of different voltage capabilities. It's should be the same for 1N916s being subbed for 1N914s. I'm sure I've done that one
Homer: "Mr. Burns, you're the richest man I know"            Mr. Burns: Yes Homer It's true... but I'd give it all up today, for a little more".
Big Ones yeahhh...yanked a bunch, threw some on the diodes tester, looked PDGood for PS Protection...haven't have a peep out of them yet.
barret77
hey, thanks for the feedback.
here are the datasheets of both. I'm considering the FRED diode because I've read audiophiles confirming their quality, plus Aiken amps use them.
http://rocky.digikey.com/WebLib/IXYS/Web%20Data/DSEI12.pdf
http://www.vishay.com/docs/88503/1n4001.pdf
The DSEI12 is much more powerful, my question is reallly if it will give any problem replacing de 1n400X family...
parietal_03
Please, forgive my ignorance and present lack of understanding.
But to be sure...In repairing my Boss DS-1: I may successfully replace the IN4004 rectifier (labelled "D1") with an IN4007 without problem, but if I replace it with an IN4001 I should look forward to an mini-explosion?
"...In trying to prove that a system of proportions has been deliberately applied...one is easily misled into finding...those ratios which one sets out to find. Compasses in the scholar's hand do not revolt."
parietal_03
http://diystompboxes.com/sboxforum/viewtopic.php?t=28729&highlight=in4004+diode+substitutions
Nevermind... :shock: Erm...Oh look...something...that um...takes me away from my stupid post.
