Simple Resistor Question (hopefully)
Started by madcat, February 08, 2005, 11:28:26 PM
madcat
Is it ok to mix 1/2 watt and 1/4 watt resistors in a circuit when one or the other is called for? Thanks in advance.
a witty saying proves nothing
NaBo
well, if it says 1/4 watt, you can use 1/2 watts.  they're usually a bit bigger though.  if it specifically says 1/2 watt, then don't use 1/4 watts.  they're just specifying the MINIMUM rating.
jimbob
Theyll (1/2 watt will just look a little goofy there w the 1/4 watt ones. Other wise all good in resistor land.
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
