prof tweed + poweramp = bad sound :(
Started by bentium, February 09, 2005, 09:24:36 AM
bentium
hey
i just build the prof tweed (good sound, though i have to change the cap in feedback loop, i used a 1µf, the sound is not bright enough for me) and i've build a poweramp section (a regular 18w 'hifi' amp with 2 tda2003 in push-pull config (http://www.circuitsonline.net/circuits/sch/000011.gif)
bot work fine (connected poweramp to cdplayer: sound is good, preamp to guitaramp), but together sound realy sucks and it's to quiet
how can i fix this? buffer? cabsim??
bentium
bentium
i just build http://www.generalguitargadgets.com/richardo/practiceamp/lm383.gif
used it with the prof tweed, same result :(
does anyone have a good poweramp section for this preamp???
i want it to be in the area of 10-15w
i stil have some tda2003 at home
smashinator
One thing is that you have to limit the volume from the professor tweed so it doesn't make the power amp chip distort.  That could definitely sound like poo.
People who say it cannot be done should not interrupt those who are doing it. - George Bernard Shaw
http://pizzacrusade.blogspot.com/
bentium
Quote from: smashinatorOne thing is that you have to limit the volume from the professor tweed so it doesn't make the power amp chip distort.  That could definitely sound like poo.
any suggestions on how to???
smashinator
Personally, I'd crank the "volume" pot all the way up, and start out with the "master volume" at a minimum, and slowly increase the master volume for as long as the power chip stays undistorted (I'm guessing you'll notice...).
