FET as diode
Started by seanm, February 09, 2005, 10:39:36 PM
seanm
In the simple mods/tips section it mentions using a FET as a diode. Any recommendations on a FET to use? Would a 2N7000 MOSFET work well?
Sure @@@
 I liek 2n7000 or Jfet or Si
 Just use G/S of fet
 or B/E on si's and Ge's
amz-fx
The Shaka 3 that I developed with Aron uses mosfets for clipping diodes:
http://www.diystompboxes.com/pedals/shaka3.jpg
regards, Jack
There are three ways a FET can be used as a diode.
(1) JFET gate-channel diode. Short drain and source, and forward bias the Drain/source to the gate terminal. This is an especially low leakage, but high resistance diode.
(2) MOSFET substrate diode. Short source and gate and the source/gate and drain works in the reverse direction of normal conduction. This diode is a fairly normal silicon diode
(3) diode connected MOSFET. Short gate and drain. The MOSFET now acts like a higher forward voltage (2-3V) but very soft clipping diode.
Actually, there is another way. If you connect the gate and source of a JFET, the JFET will regulate current through the JFET at all voltages over Vp. The current it regulates to is equal to the JFET Idss.
seanm
Quote from: amz-fxThe Shaka 3 that I developed with Aron uses mosfets for clipping diodes:
regards, Jack
Is the diode attached to the MOSFET necessary, or is it for tone reasons?
seanm
Quote from: R.G.
Is this litterally a diode on a MOSFET like the Shaka 3? I want to soften the distortion, more like a tube amp on 10.
Paul Marossy
All BJTs, MOSFETs and JFETs have the capacity to become diodes when connected in such a manner as to make them function like diodes.  :wink:
I built Joe Davisson's Amber Boost several years ago and it used 2N7000s as clipping diodes. It sounded pretty good!
