New TS-808 clone and BSIAB II clips
Started by scottosan, February 11, 2005, 10:35:54 PM
scottosan
Ok, here is the deal guys.  I had very limited time so I just put this together really quick.  The way I recorded these was into a clean amp with no break up.  At the beginning of the clip you will hear some clean guitar and then I will enguage the pedals on and off, switching back and forth between the 2.  I figured it would on be fair to demonstrate these during the same session with identical amp setting, volume, etc.. I did add some reverb after the final recording and couldn't undo it so I appologize if you wanted to here it dry.  I will seperate the tracks this weekind, but for now you will just have to listen for each pedal.  I won't be that hard because the 808 doesn't have nearlya s much gain as the BSIAB II.  The pedals had all of the knobs at 12:00 until the end when I turn up the gain on the 808 to full.  In case you are wondering, I used a Tokai Gold top Les Paul with a Custom 5 in the bridge and PAF Pro in the neck->pedals->clean channel of Bogner XTC101b with tone setting to 12 o'clock for nuetrality.->M-audio fasttrack($99 at GC)
http://www.digitalsoundplanet.com/Members/000139610_000025565.mp3
Sounds Great, Excellent Tones !!!
 Bogner Sounds Real Nice Clean, LoVeS those Boxes !!!
MartyMart
Nice clips, they sound great !!
Marty. 8)
