SOT: Firefly amp stuff and questions
Started by brett, February 13, 2005, 08:21:51 PM
brett
Hi.
I've just finished building a Firefly valve amp, designed by Doug Hammond.  It's an excellent project, even for someone who hasn't built a valve amp before (like me).
My question is about impedance and the output transformer.  In the most recent schematic at Doug's site,  (http://home.cfl.rr.com/dbhammond/Firefly_sch_R3.gif) the primary z is shown as 22.5 kohms (8 ohm secondary).  However, the transformer connections (2 and 5) shown at Paul Marossy's site (http://www.firebottle.com/ampage/homebrew.cgi?cat=ga&sb=&so=hl&page=1076726808cSGgrKj) correspond to a primary z of 8.2 kohms.
I've used Paul's wiring layout, but wish to know whether and how the lower primary impedance will affect the output tube and amp.  I suppose there'll be extra output current (?) Extra power? Different tone?  Shorter tube life?  As you can tell from these questions, I know little about tubes.
thanks for any help
Brett Robinson
Alex C
brett
Thanks Alex.  That thread had everything I was looking for.
I have obviously missed some of the old firefly threads.
As always - search, search and search again.
The Firefly is so excellent - I'll post some pics on my site soon.
Brett Robinson
Paul Marossy
brett-
So, was there anything misleading on my Firefly page? I think I have all the bugs worked out on that one now...
EDIT: Oh darn, I see that my chassis layout has that OT secondary mistake on it. I'll need to fix that.  :oops:
brett
Paul.
your site was FANTASTICALLY helpful.  Finding it (and your layout in particular) was what made me go ahead with building a firefly.
BTW, my "cascode" tube glows a lot more than the 2 x normal stage tube.  Is this normal?  The tubes are different brands (one is a large plate and one a regular plate 12AX7), so that might partly explain things.
Again, many thanks for the excellent information at your site.
Brett Robinson
Paul Marossy
QuotePaul.
brett-
That's cool, I like it when I can help people like you out and hopefully be somewhat of an inspiration.  :)
Anyhow, I'm going to fix that layout in the next day or two. As far as the cascode tube goes, I wouldn't worry about that too much - as long as your heater voltage is within 5-10% of what is specified, you're fine.  I have noticed that some tubes seem to be brighter glowing than others. 8)
Paul Marossy
Just for the record, I've updated that chassis layout to show 2 and 4 on the OT secondary, and the connection to ground at the volume control.  8)
It can be found here: http://www.diyguitarist.com/PDF_Files/FireflyChassis.pdf
