DIY tape echo is possible for me!
Started by panasonic_youth, February 13, 2005, 09:43:10 PM
panasonic_youth
i have the playskool 'my first tape recorder' tape recorder, and i was just going to do the whole echo thing the really really tedious way(mounting and wiring individual play heads) when i stumbled upon this: http://moosapotamus.com/Echo-Matic_a.jpg and http://moosapotamus.com/Echo-Matic_b.jpg  !  if someone would tell me what the offboard connections are, i could probably do this. i just want to make sure im straight on this, the echo-matic DOES use a tape deck, does it not?
panasonic_youth
also, i dont quite understand the need for a 3 headed tape deck in that circuit. as far as i can tell it reads: guitar goes into amplifier stage, which goes out to recorder input.  recorder output goes to another amplifier.  thats very simplistic, i know, but doesnt that just require one playback head?  it seems to me that it does, but i may just be excited right now.
EDIT
one last thing, when it says: in from tape output, does it mean the actual head, or the entire unit's output (or what the speaker leads would be, in my case) ?
Maneco
because the three heads are: 1) erase head 2) record head 3) playback head...in a normal cassette deck,the record and playback head is the same,the record switch inverts the function of it...
panasonic_youth
ahh, alright, so i will have to add the aditional play head?
Khas Evets
For me, not having control over delay time is a minus. Do you have control over the speed of the tape deck?
panasonic_youth
most tape decks have a trimpot for speed, but you could install a pot as a variable resistor right to the motor. so yea, you have control.
mathflan
Hi, I have A JVC KD-A2 Stereo cassette deck.
On the manual it's marked that there:
2 heads CRONOIS head for recording/playback and
2 gap ferrite head for erasure.
Do you think it's a 3 head tape desk??
CAn i use this for the Echomatic??
http://sounddiy.free.fr
