millenium bypass
Started by Narcosynthesis, February 16, 2005, 04:32:11 AM
Narcosynthesis
hello, i want to use the millenium bypass like shown at geofex(http://www.geofex.com/Article_Folders/Millenium/millen.htm)
for the millenium 2, it mentions using a 1N914 or 1N4148 and a low leakage diode, what type of diode would the low leakage one be?
David
jimbob
the 2 are the same really. Ive built many of these and for some reason half work and the others dont. I used the j201's so that might be why.
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
Use the collector-base junction of an ordinary NPN transistor for the low leakage diode. Snip off the emitter lead, use the two remaining ones. Use the collector for the cathode/bar and the base for the anode/arrow.
