New at Topopiccione: EH Bad Stone
Started by Zero the hero, February 20, 2005, 08:36:35 AM
Zero the hero
I did it!
After hours of soldering and testing, it worked. The first time I plugged it into the amplifier it didn't work, due to a broken transistor (stupid 2N3904, you took 1 hour of my life away).
Then this thing started phasing like I've never hear before! It sweep from small phasing to extreme chorus/flanger like sounds.
The layout was a bit messy, but it was the only way to fit 6 ICs in a small board.
I'll post the complete build article on my site very soon (tomorrow if I'll have time...).
EDITED: It's on-line now at http://topopiccione.atspace.com/
under "Projects" --> "Electro-Harmonix Bad Stone"
puretube
StephenGiles
Zero  - well done! It's a great phaser - did you use a 4009 or a 4049?
Stephen
Zero the hero
I used both for testing. I noticed that the 4049 gives a less pronounced phasing, but I might be wrong...
dpresley58
Congratulations!
Which schematic did you use, Zero..?
Little time to do it right. Always time to do it over.
B Tremblay
Quote from: Zero the heroI used both for testing. I noticed that the 4049 gives a less pronounced phasing, but I might be wrong...
I noticed slight differences between the two in my vintage Bad Stone, but nothing that would make me choose one or the other.
B Tremblay
runoffgroove.com
Zero the hero
Quote from: dpresley58Congratulations!
The one posted on GGG, although it had a minor error.
sir_modulus
Good job! I've been lokking to build a bad stone sometime. Is there a chance for audio samples?  :D
Cheers,
Nish
B Tremblay
Quote from: sir_modulusIs there a chance for audio samples?
This page has a few from my store-bought unit:
http://home-wrecker.com/badstone.html
B Tremblay
runoffgroove.com
Zero the hero
Thanks for the sound samples! My unit sounds pretty the same, it only feature a higher max frequency rate.
I have a computer with no analogue in, so I have no chance to record samples now... :oops:
puretube
hah: so you need a digital phasor...  :P  :oops:  :lol:
Maneco
Congratulations...from the clips,that's one of the finest phasers i've heard...if you want,i can collaborate in designing a layout for this community...enjoy it...
sir_modulus
Wow...the bad stone has such an "organic" and deep sweep! I like it a lot!
Cheers,
Nish
Zero the hero
Thanks in advance Maneco, but the layout is ready! I've drawn it with Photoshop and I only have to finish some minor details, like writing an article, taking some pictures and triple checking everything...
If I'll have enough time, I think that tomorrow an article will appear on my site!
Maneco
WOW! thanks...i know what i'll build next for my pedalboard...
Zero the hero
It's online now at http://topopiccione.atspace.com/
under "Projects" --> "Electro-Harmonix Bad stone"
Enjoy!  8)
sir_modulus
Awsome man! Thanks! I look forward to building this!
Cheers,
Nish
