2 Loops with ISD chips for mobius pedal or dirtysam pedal??
Started by mathflan, February 21, 2005, 06:22:51 AM
mathflan
HI
I'am wondering if it's possible to record two differents loops with a ISD Chips.
SO I could record loop 1 and a loop 2 on
the morbius pedal :
http://www.generalguitargadgets.com/pdf/ggg_mobius_trip_pcb_lo.pdf
or
dirtysam:
http://humano.ya.com/guruzeta/Guitarra/dirtysam/
http://sounddiy.free.fr
The Tone God
Quote from: mathflanI'am wondering if it's possible to record two differents loops with a ISD Chips. SO I could record loop 1 and a loop 2 on
It depends on the IC. I'm too lazy to look at the links you posted but when I played around with audio recorder ICs awhile back I created a multi-sample feature. It made use of the address lines availible on the ICs I was using. By manipulating the address lines I was able to slice the memory up into pieces and call them at will. It takes some extra circuitry but its not tough to do.
Take a look at the IC's "all-knowing" datasheet.
Andrew
puretube
with the newer generation voice-corder chips, you can record  16 loops,
and IIRC, about half an hour audio, without increased sound quality...
ethrbunny
Quote from: puretubewith the newer generation voice-corder chips, you can record  16 loops,
increased or decreased?
and whats IIRC?
--- Dharma Desired
"Life on the steep part of the learning curve"
puretube
