original BOSS DC Jack pin question
Started by Marek, February 25, 2005, 10:15:40 AM
Marek
Hi all!
How thick is the inner pin on the original BOSS DC jack?
2.1 mm or 2.35 or 2.5 mm??
The outter barrel is  5 mm, that much I know. :-)
Thanks in advance,
Marek G.
dpresley58
I use the Boss PS unit to power mine, and I -believe- it has a 2.5 pin... Radio Shack has them as an "M" size, regardless.
Another consideration is that since most Boss pedals are (-) to the pin and (+) to the barrel, you're going to have to reverse that, unless you installed an insulated jack. I bought the plug and a jack and wired them together so I could get it into my build with the (-) at the barrel, since my build's jack grounded itself to the enclosure.
Little time to do it right. Always time to do it over.
phillip
I think it's 2.1mm.  I have a 5mm outside / 2.1mm center pin daisy chain that fit my Boss SD-1 and DS-1 perfectly.
Phillip
El Caballo
The standard power connector is a 2.1mm barrel jack, sometimes known as a P-5.
