......and another sustain unit!
Started by StephenGiles, February 25, 2005, 04:59:58 PM
StephenGiles
radio
Hi again
Good search,by the way the initial topic was how to change
russian kP303 bigate fet with 4 legs to regular j201.
The analogy is that this error amp comp of Silicon chip au has published in
1998 had to substitute
the bigate fet.
As a result you should try b for a to get first version,some resistor
changes too.I tried both version ,oscillation is a issue that only is
avoided by soldering pots directly,i insist,on PCB
A mistake I made never substitute any value around control current of
error amp even as low as 3%away from original.
Could scan technical explanations if you need them?
Greetings JMErnzer
Keep on soldering!
And don t burn fingers!
