What is a good low noise substitute for a 2N5457 JFET?
Started by BlackFlag1313, February 28, 2005, 10:25:19 AM
BlackFlag1313
I've been trying to reduce as much noise as possible from an Orange Squeezer circuit.  I've tried low noise IC's, metal film resistors, etc.  Anyone have an idea for a low noise JFET that would work in this circuit.  Thanks!
maximee
this is taken from http://www.generalguitargadgets.com/index.php?option=content&task=view&id=47&Itemid=79
QuoteI am FINALLY satisfied with my orange squeezer. The secret was low gain fets (MPF102) , with the bias pot as low as possible, a .015 input cap, with a 1uF np output cap and a JRC4558 opamp. The 4558 sounded a whole lot smoother than the TL072 :-) FYI.
Note from JD: I tried the MPF102 FETS and I think I like the 2N5457 better.
there is a whole lot more info on the OS circuit as well...
worth checking out.[/url]
j0shua
You can use 2N5458 appears to be same Transistor but i like more the new 2N5458 ......
orange squeezer is one of the best compressor and very easy to build.....
i like more the 4558 IC :)
