A/B box problems
Started by fusion711, March 01, 2005, 01:01:24 AM
fusion711
I've made a simple A/B box as my first attempt at a pedal. When testing it on its own it works perfectly, but as soon as i plug an effect pedal into one of its outputs, the other output won't work. I then plugged another pedal in the other output, but no improvement. I've moved all the leads into every possible configuration with no luck. Any ideas as to a solution.
The box is just one input, going into a DPDT switch, which goes into the two outputs and an led for each. It is powered by a 9V power pack.
I had also read somewhere about using a resistor to eliminate the popping noise when switching channels, but cant find specifics. Where should this be attatched.
siaoguitar
try the silent tuning circuit at the FAQ section, it's actually a n A/B box u can build.
I've tried it and it works!!
