ea trem in wah shell to volume pedal conversion Q
Started by nightingale, March 03, 2005, 12:00:32 PM
nightingale
i built the ea trem into a wah shell using the wah pot to control the "rate"..
i used the ROG schemmo: http://runoffgroove.com/eatremolo.html
now i have decided that i would like to swich it between volume/trem modes with a toggle on the side.
i can't figure out how to modify the circuit to make the "volume pedal mode"work correctly. i know that i can't just hook the switch right up to the "rocker pot" to control the volume?
i know that volume pedals have some actives inside of them. i was thinking that it would be possible to use the mosfet part of the ea trem?
or somehow i could wire the swtch to bypass the trem, and then wire the "rocker pedal pot" to control the volume when the switch is thrown.
sorry if this is a little confusing.
any ideas?
be well,
ryanS
www.moccasinmusic.com
bwanasonic
Quote from: nightingale
Some do, but many don't, including the venerable Ernie Ball 6166. It's just a 250k pot, and a little internal switch that toggles in a resistor to vary the taper.
Kerry M
Transmogrifox
PM me your email address and I'll send the schematic as I have modified it in MS paint.  It requires a DPDT toggle, but it should work just fine.
trans·mog·ri·fy
