Nice looking Ibanez EM5 delay
Started by StephenGiles, March 03, 2005, 02:03:26 PM
StephenGiles
object88
It's, er, terribly small and hard to read, I'm afraid.  I can't make out a lot of what's on there.
StephenGiles
Oh, I thought it was my eyesight!!!
Stephen
casey
if you use a viewer called "irfan view"  it'll take care of the small schematic problem....
later-  :)
Casey Campbell
TheBigMan
It's a great sounding digital delay.  It actually has a built in distortion circuit to give it a much more analog sound.  Robert Keeley is working on a clone of it at the moment.
object88
Oh, that's MUCH better!  :)
Another question... what's the difference between caps C32, C33 (bottom right), C21 (in the feedback loop on the output op-amp), and C2 (between the two op-amps after the input)?  One is hatched, the others are not, but with a triangle, square, and maybe circle on one side.  Never seen that before...
puretube
the hatched ones are electrolytics;
irfan-view didn`t make the small schem "sharper";
the delay-chip is obsolete,
but similar to some Princetons/Holteks...
pyrotek
What is CP? Is it a component? It is connected at the output of one of the inverter...
TheBigMan
Quote from: pyrotekWhat is CP? Is it a component? It is connected at the output of one of the inverter...
Check Point probably.  The service notes usually show how the wave form would look on an oscilliscope at these points.
