Question about printing PCB layouts
Started by rubberlips, March 04, 2005, 07:44:18 AM
rubberlips
just a quick one about printing PCB layouts to laser printers.
If you want to print the layout to a film (like PnP or overhead sheets) should the layout be flipped (verically or horizontally) so it's a mirror image - generally speaking?
Cheers
Pete
play it hard, play it LOUD!
Rodgre
Yes, the image should be reversed, so when you look THROUGH the sheet from the other side, you should see the correct image. When you iron it onto the board, that's how it will end up.
Roger
