Need a Pic of SansAmp CLASSIC PCB
Started by triskadecaepyon, March 06, 2005, 12:37:00 AM
triskadecaepyon
Anyone got a picture or can take a picture of the inside of a Sansamp Classic?  I'm trying to route it, so I need a couple pictures for direction.
MartyB
If you're wanting to make a layout or a diy project of this pedal you might want to check this link out:
http://tonepad.com/project.asp?id=22
MartyB
mat
Here You have:
http://tinypic.com/214z6c
http://tinypic.com/214z8h
http://tinypic.com/214zgh
Funny thing, I cannot find a single IC or transistor from it ?
cheers,
mat
triskadecaepyon
Quote from: MartyBIf you're wanting to make a layout or a diy project of this pedal you might want to check this link out:
MartyB
The sansamp Classic, not the GT-2.  I already have one.
triskadecaepyon
Quote from: mat
cheers,
mat
The reason they do that is because they hide the IC's in that white plate where the DIP switches and the Pots are.  Supposedly their "secret design" is what makes their 245 dollar pedal sound so good.  Someone in Japan reverse engineered it so they could make the schematic.  Otherwise, Thanks for the Pics! now I can see how they designed it!
mat
The distance between the white plates is 1 millimeter  :shock:
Must be some kind of a miniature ic's/transistors..
mat
triskadecaepyon
Well, if you look at the schematic, there is 2 IC's and 1 transistor.  The rest are those tiny resistors and caps you see everywhere else.  Btw, is that your Sansamp?
sir_modulus
Where is this schematic? Also, SMT parts can easily fit under that piece of plastic.
Cheers,
Nish
sir_modulus
Cool awsome!
heres a link to the real deal, incase anyone was curious:
http://www.tech21nyc.com/classic.html
Cheers,
Nish
triskadecaepyon
This thing is outrageously diffiuclt to make a PCB with.  I hope it really pays off if it works.
gak
was that schematic tested??
it would be great to clone a sansamp classic!
triskadecaepyon
Hence my work on it.  I plan to separate the PCB into four parts, to make things simpler.  Hope people are looking forward to it!
Prive
I have a pcb layout in some cd, i'll make a search and send it by email, it's not tested by me but you can do it and correct it if necessary.
PM me your email adresses and wait some days.
Saludos, Marcelo.
Fuzz boxes don't need on/off switch!!!!!!!!
mat
Quote from: triskadecaepyonWell, if you look at the schematic, there is 2 IC's and 1 transistor.  The rest are those tiny resistors and caps you see everywhere else.  Btw, is that your Sansamp?
Ok!
Yes it's mine, why ?
There is something wrong with it, i'll have to fix this thing....hmmm...
cheers,
mat
